It is currently Sat Aug 02, 2025 7:30 am
 Post subject: Feet slotting jigs?
PostPosted: Mon Apr 08, 2019 11:34 am
Good morning fellow sawdust makers / wood tappers.
I’m looking into manual fret slotting jigs. There are a few
Out there from the big companies, but I wanted to see if the experienced users in the group had a favorite and why?
Thank you for any input
Have a great day!
B Snow
 Post subject: Re: Feet slotting jigs?
PostPosted: Mon Apr 08, 2019 11:52 am
City: U.P.
By manual do you mean by a hand saw? i.e. no motorized tools.
Brian R
Brian R, Wood Mechanic
N8ZED
PostPosted: Mon Apr 08, 2019 12:15 pm
Brian R
I’m not opposed to a small table saw system. I really just don’t
Know a lot about it .
PostPosted: Mon Apr 08, 2019 12:37 pm
I think a manual saw system makes sense for me provided the small number of builds I do a year
BUT I want to buy once / cry once
PostPosted: Mon Apr 08, 2019 12:41 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
If you have an extra $1200 laying around
https://m.youtube.com/watch?v=3ruwZdaPjbs
PostPosted: Mon Apr 08, 2019 12:42 pm
First name: Brad
Last Name: Combs
If you decide on this one, I have a older version that is collecting dust: https://www.lmii.com/fretting-tools/270 ... ystem.html
Will let it go for a good price. :)
PostPosted: Mon Apr 08, 2019 12:43 pm
First name: Brad
Last Name: Combs
BTW.... the title is painful sounding. :D
These users thanked the author bcombs510 for the post: Michaeldc (Mon Apr 08, 2019 1:44 pm)
PostPosted: Mon Apr 08, 2019 1:54 pm
Haha I just busted out laughing at the office ha
Yes... yes it is painful
PostPosted: Mon Apr 08, 2019 4:12 pm
I use the LMI power slotting system. It's never let me down. I prefer it to the stewmac blade with the built in stiffener as you can cheaply replace the blade and use the same stiffeners, as well as using the stiffeners with other blades like the diablo when cutting bindings. I also use the same .025 blade for cutting purfling and bindings with a zero clearance insert. Just with an inexpensive dewalt saw.
Having a tablesaw in the shop can be handy for a lot of things...
PostPosted: Mon Apr 08, 2019 5:56 pm
City: Tyler
Same here. I got the fret template and blade from LMI and love it. I put it in a Dewalt portable table saw I had upgraded from. Use it only for my once a year fret slotting. Accurate and takes about 1 minute.
PostPosted: Mon Apr 08, 2019 6:02 pm
I’ll look into this. Does it work with a regular table saw?
PostPosted: Mon Apr 08, 2019 6:17 pm
"BUT I want to buy once / cry once "
I used to draw the lines on the fretboard, clamp a small block of wood on the line to guide the saw and cut slots with a back saw. It is the cheapest way to do it, and probably as fast and easy as using most of the jigs out there.
Eventually I made a small table saw, which for the limited adjustments needed for cutting frets is not hard to do.
PostPosted: Mon Apr 08, 2019 6:23 pm
City: Tyler
I believe so. I just measured the arbor size on mine and checked what LMI spec’d and was good. I don’t remember the measurements.
PostPosted: Mon Apr 08, 2019 9:26 pm
I have used the LMI templates and blade/stiffners for 14 years with a sled design from Sylvan Wells’ website. Works great.
One warning, the blade is thin and depending on the thread width on your arbor, can drop into a thread groove and get a little eccentric. On my old DeWalt portable saw that happened and the hole in the blade actually deformed a little. Still worked OK although a test cut was critical for depth.
On my Delta saw narrower threads and all was OK.
